Question Fender/Cowl Seals?
Any experience with the fender to cowl seal that Pelican sells? Are they OEM, or after market of the same design? Should one insist on the OE part for better sealing?
TIA
Old 05-19-2003, 12:06 PM
914 Geek
AFAIK, those are OEM seals.
--DD
Old 05-19-2003, 01:41 PM
norustscott's Avatar
Pelican Parts worked ok for me...First thing is to clean out the groove. check for rust, recheck for rust...once you can admit to yourself that is is alittle rusty, remove all of the scale(ly) stuff and treat with POR15. I used a very small paint brush and took my time. You may have to thin the POR15...remember POR15 suggested mulitple thin coats. Once Dry install seals...I blw out this area with compresses air after washing or getting cought in the rain...anal, yes. But I have seen fist size rust holes @ the cowl seal...
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 05-19-2003, 01:45 PM
green71's Avatar
Their cowl seals worked perfectly. Now all I need is a new paint job to make them look good.
Mark
1971 1.7l 914
Old 05-19-2003, 02:24 PM
porsche914blue's Avatar
How do you replace the cowl seals? Does the fender have to come off or do they slip out?
1974 914 2.0L Marathon Blue
Old 05-20-2003, 05:12 AM
They "slip" in kind of a crimp fit....
Scott
1982 911 SC
1962 sunroof bug
Old 05-20-2003, 06:50 AM
david914's Avatar
They will come out with a little (or alot of) pursuation. Warm up the new ones with a hair dryer (not too much!) to make them easier to install evenly.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 05-20-2003, 02:53 PM
Va914's Avatar
Does anyone put clear silicone in the seam before the cowl seal?
Cheers
Kerry
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 05-20-2003, 04:41 PM
david914's Avatar
I don't think that would be a very good idea since the silicone would cause more problems than it may solve. The idea of the cowl seal is to (of course) keep water out of the seam. IF any moisture were to get into the seam the silicone would hinder the moisture from evaporating. Most damage in this area is because the cowl seal has deteriorated (shrunk) and is not functioning the way that it should. The seal should extend slightly beyond the metal so that water will run off the ends of the seal rather than into the seam.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 05-20-2003, 08:13 PM
