How to get the seats out
I need to re-upholter my 914 seats but can't get the Darn things out the car
Is there a video showing the seats being removed from a 914, I've read about it, attacked them with tools, I simply don't understand how to do it. Hopefully someone can send me a video link where I can see it being done, as opposed to reading about it Many Thnx
1973.5 911T Coupe yellow '02 Carrera Coupe C4S Black |
Just move seat to full front position ( short person). Look behind on the tracks and you will see two bolts on each track, remove with 10mm socket. Done
1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover |
914 Geek
Umm, there are two more bolts to remove--the ones at the front of the tracks.
The easiest way to remove the seats from a 914 (except the passenger's seat of a 70 or 71 car!!) is: - Pull up on the seat slider lever (it has a loop-shaped handle on it unless the handle has broken or been replaced) and slide the seat all the way forward. - Reach under the other seat rail and feel for a metal tab sticking downward. Push that tab up, and slide the seat the rest of the way forward, off of the seat rails. If the brackets need to come off the floor pan at that point, you can very easily access the mounting bolts without the seat in the way. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Dave, what bolts up front, is the 70/71 different than my 74..Mark
Hope you can attend. Click the link below for details. 914World.com - The largest online 914 community! |
Don't need to remove toothed comb, just pull the adjustment lever and lift to the rear. I've done it four times this month......added sound deadening. Wish I had a swap meet to go to. Mark
914 Geek
The 71 has the fixed passenger seat. The seat bottom is a separate part from the seat back, which is part of the back pad. I don't remember how the seat bottom comes out. --DD
The 9 Store
All used parts sold as is. |
