-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Front disc problem (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/110311-front-disc-problem.html)
elwood-914 05-11-2003 06:17 PM
Front disc problem
Hi all,
I finally sandblasted the sheetmetal disc brake guards, painted them and today I installed them. I slid on the new disc rotor that I got from P.P. and it bottoms out and hits the sheetmetal. What gives? Did I get a pre 73' disc by mistake. How are the pre 73' discs different? There isn't enough threads on the hub to install the clamp nut. By the way I have a 1973. I also can't compare the new discs with the old since I discarded the old ones. Can anyone shed some light on my dilema? Thanks for your help.:confused: :confused: :confused:
URY914 05-11-2003 06:48 PM
Sounds like you got an early set of discs.
It happens.
Lay one flat on the ground and measure the offset by laying a stright edge across top and measure to the face of the disc. Post what the measurement is and I'll check it with my '73.
Paul
elwood-914 05-11-2003 07:36 PM
Hi Paul,
I measured 2 7/16" to the face and 2 7/8" to the back of the disc. Thanks
URY914 05-12-2003 05:31 PM
I measured mine while on the car-it looks like from the disc face to the wheel mounting surface there is 2 1/2". So yours is further to the inside by 1/16". Does that sound right?
Paul
Kevin Powers 05-12-2003 06:42 PM
you don't have the backing plate on wrong side out do you? the curved outer edge side faces the center line of the car, not covering the rotor.
kevin
elwood-914 05-12-2003 06:57 PM
Kevin,
Am I an idiot or what. It's been awhile since I had the brakes off, I just assumed that the shield cuved towards the rotor. I tried looking at different pictures in the Haynes manual but not too many good ones. I'll turn those buggers around. Thanks a bunch. Hope it works.:rolleyes:
Kevin Powers 05-12-2003 07:33 PM
i just did my brakes too. painted the backing plates too. guess why i thought that might be the problem? luckily i did one side at a time. only had to redo one.
kevin
elwood-914 05-12-2003 08:04 PM
Kevin,
Thanks a lot! They went on just fine but it still looks odd. It still seems the curved part would protect the disc. But what the hell do I know. Just when I thought I was semi mechanical. shesh:D
elwood-914 05-12-2003 08:06 PM
Paul,
Thanks for taking the time to check the measurements.SmileWavy
Kevin Powers 05-13-2003 04:57 AM
it does seem backwards and looks odd. but who's ever going to see them?
kevin
mike95125 05-13-2003 09:08 AM
I did the same thing reacently. Don't feel bad.
