elwood-914's Avatar
Question Front disc problem
Hi all,
I finally sandblasted the sheetmetal disc brake guards, painted them and today I installed them. I slid on the new disc rotor that I got from P.P. and it bottoms out and hits the sheetmetal. What gives? Did I get a pre 73' disc by mistake. How are the pre 73' discs different? There isn't enough threads on the hub to install the clamp nut. By the way I have a 1973. I also can't compare the new discs with the old since I discarded the old ones. Can anyone shed some light on my dilema? Thanks for your help.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 05-11-2003, 06:17 PM
Sounds like you got an early set of discs.
It happens.
Lay one flat on the ground and measure the offset by laying a stright edge across top and measure to the face of the disc. Post what the measurement is and I'll check it with my '73.
Paul
Old 05-11-2003, 06:48 PM
elwood-914's Avatar
Hi Paul,
I measured 2 7/16" to the face and 2 7/8" to the back of the disc. Thanks
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 05-11-2003, 07:36 PM
I measured mine while on the car-it looks like from the disc face to the wheel mounting surface there is 2 1/2". So yours is further to the inside by 1/16". Does that sound right?
Paul
Old 05-12-2003, 05:31 PM
you don't have the backing plate on wrong side out do you? the curved outer edge side faces the center line of the car, not covering the rotor.
kevin
here? not so much i think. high five!!!
Old 05-12-2003, 06:42 PM
elwood-914's Avatar
Kevin,
Am I an idiot or what. It's been awhile since I had the brakes off, I just assumed that the shield cuved towards the rotor. I tried looking at different pictures in the Haynes manual but not too many good ones. I'll turn those buggers around. Thanks a bunch. Hope it works.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 05-12-2003, 06:57 PM
i just did my brakes too. painted the backing plates too. guess why i thought that might be the problem? luckily i did one side at a time. only had to redo one.
kevin
Old 05-12-2003, 07:33 PM
elwood-914's Avatar
Smile
Kevin,
Thanks a lot! They went on just fine but it still looks odd. It still seems the curved part would protect the disc. But what the hell do I know. Just when I thought I was semi mechanical. shesh
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 05-12-2003, 08:04 PM
elwood-914's Avatar
Paul,
Thanks for taking the time to check the measurements.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 05-12-2003, 08:06 PM
it does seem backwards and looks odd. but who's ever going to see them?
kevin
Old 05-13-2003, 04:57 AM
mike95125's Avatar
I did the same thing reacently. Don't feel bad.
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 05-13-2003, 09:08 AM
