Barber Dave's Avatar
Thumbs up Help
I bought a rear view mirrow that mounts to the center mount
for the sun visors. QUES. is how do I get the old one that's glued to the windshield off with out breaking anything. ( windshield).
I't a stock glued on one. Is there a solvent to desolve the glue. Or do VERY carefuly chip away at it. Some one out there has to have taken one off before. Thanks all in advance.
DAVE
Rennlist Member
S.M.O.G.
914 Club
M.V.R.P.C.A.
73,BLACK ,2.0
Old 05-15-2003, 04:43 PM
Rob914's Avatar
Send a message via AIM to Rob914
I used alot of goo gone, chipped at it, and pulled it off, may not be the smartest idea
http://www.pelicanparts.com/gallery/Rob914/
76 914
Old 05-15-2003, 07:31 PM
chrisreale's Avatar
maybe heat the outside of the glass with a hair dryer, and gently rock it off?
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 05-15-2003, 07:46 PM
scg scg is offline
scg's Avatar
Sorry I can't help... I'm just amazed it hasn't fallen off already!
You might call up your local windshield dealer and ask how they do it...
Scott
74 914-6 2.7
Old 05-15-2003, 07:56 PM
chrisreale's Avatar
Yea, mine fell off whe I was adjusting the mirror!
www.914club.com
Old 05-15-2003, 09:06 PM
Potter's Avatar
Send a message via AIM to Potter
I'd say that setting a priceless crystal vase down by the shifter and then really hoping nothing bad will happen to it should just about do it. Chances are excellent you will be shop-vacuuming in between five and ten minutes.
'73 914 2.0
"Seriously Honey, the part was really really cheap...........honestly"
Old 05-15-2003, 11:17 PM
I'm with Chris Reale. Heat gun on the outside.
Dave, unless the sticky-pad has been replaced it's usually pretty weak and comes off easy... but then there are the exceptions.
Chris H.
'75 914 3.3
Old 05-16-2003, 05:38 AM
REAR VIEW MIRROR
CHRIS: IT LOOKS LIKE IT HAS BEEN REPLACED AND NOT A VERY CLEAN JOB EATHER ,GLUE IS GOBBY. I WILL TRY THE HAIR DRUYER TONIGHT . HEAT IT UP REAL GOOD AND THEN GO AT IT WITH A PUTTY KNIKE? OR JUST PULL AND ROCK? DAVE
Rennlist Member
S.M.O.G.
914 Club
M.V.R.P.C.A.
73,BLACK ,2.0
Old 05-16-2003, 09:05 AM
norustscott's Avatar
Dave,what does the new mirror look like? It mounts to the visor hardware center T and not the windshield...?
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 05-16-2003, 10:31 AM
I'd be really careful with a putty knife Dave. Windshields for 914s are big $$$ these days. Heat it up a bit and try to rock it off carefully. If it won't budge you could try some sort of glue solvent to get some of the goop off, then back to the dryer if necessary. Prying it with a putty knife would be your last resort IMHO. I would not do that.
Good Luck, and see ya later this year.
Chris H.
'75 914 3.3
Old 05-16-2003, 01:19 PM
Twist ...don't rock...
Scott
1982 911 SC
1962 sunroof bug
Old 05-16-2003, 01:26 PM
sacook's Avatar
A red hot guitar string might do the trick also....
When I had my boat I used to throw 50 dollar bill at it when ever I went to the dock...now I do it when ever I open the garage door.
Old 05-16-2003, 02:41 PM
Kenny Powell's Avatar
there is a thread on this topic- do a search...... and I echo twist it off don't pull!
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 05-16-2003, 04:03 PM
The heat question depends on what the mirror is attached by; if it uses one of those black pads it might work (but v. doubtful, remember, the windshield in the sun already gets a lot warmer than anything your hair dryer will do) but I would go for the goo gone and a single edge razor blade (or Xacto knife). If the PO used the loctite windshield mirror glue (e.g., no black pad) then skip the goo gone and scrape at it with the corner of the single edge razor blade (that's how I did it). Or just go with Potters' idea. But nothing so thick as a putty knife.
Old 05-16-2003, 06:22 PM
skline's Avatar
You could always do it the way that works for me everytime. I usually ram my head into it while cleaning the windsheild and it just falls off. That has happened to me twice so far. Just thought I would mention it. It is a little hard on the forehead.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 05-16-2003, 07:55 PM
bowlsby's Avatar
If it is installed with stock adhesive onto the glass it comes off easy.
The adhesive will easily fail in SHEAR...like a cleavage membrane, remember how mica has layers? Same principal.
Use a STIFF blade putty knife and shove it briskly into the joint between the glass and the mirror base...right into the cleavage line.
Do n ot impose bending stress onto the glass...you may be sorry!
Voila. Catch the mirror it as it falls and dont ram it too hard or you'll damage the foam trim...
Old 05-16-2003, 08:41 PM
rear view mirror is off!!!!!
Well it was no big deal, rocked it back and forth a couple of times , ( SNAP) it was off, 4or 5 swipes with single edge razor blade and allll the glue was gone.
Many thanks to : rod914,chrisreale,scg,potter,cshosen,scott,sacook, K.powell,larry p,skline and bowlsby
you guys are the best
DAVE
Rennlist Member
S.M.O.G.
914 Club
M.V.R.P.C.A.
73,BLACK ,2.0
Old 05-17-2003, 05:43 PM
sleepdoc's Avatar
RE new mirror
Hi Dave
I saw a mirror like you described on ebay. Please tell us if it improves rear vision. It looks like it would mount a bit higher
than the glue mounted mirror, or is it designed so it hangs down to the same height. Once attached does it feel structurally sound, or does it feel wobbly.
thanks Mark
Old 05-18-2003, 02:18 PM
renatta's Avatar
Try 3M adhesive remover, Dave, and let it soak in good. you'll probably need to peel it off in layers, but it will come off eventually without breaking your windshield. You can buy the stuff at B&W Paints in Toledo.
Dave
'74 Porsche 914 2.0
'73 BMW 2002tii
'59 A-H Bugeye Sprite
'02 Audi Quatro
'10 Audi A4 Quatro
Old 05-18-2003, 03:28 PM
Thumbs up rear view mirrow
Yes, It is mouned very sound,and solid improves rear vision , doesn't hang down as far as stock. it's adjustable so you get the same image, doesn't seem to get in the way like the stock placement ,i.e. cleaning dash, and moving around in side the car working on verious things. of course i'am 280 we all know the cure for that . GIVE ME A WEEK AND I'LL POST AGAIN ON THE MIRROR AND THE SELLER. DAVE
Rennlist Member
S.M.O.G.
914 Club
M.V.R.P.C.A.
73,BLACK ,2.0
Old 05-18-2003, 05:49 PM
