-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Relay Board Question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/111281-relay-board-question.html)
seventythree 05-19-2003 11:09 AM
On the main relay board in the engine compartment, is it ok for the round male conector pins to rotate slightly? Or, would that indicate a weak/broken solder joint?
TIA
Dave at Pelican Parts 05-19-2003 12:41 PM
I believe that those joints are riveted, not soldered. I would be concerned about them rotating. (Hmm, if I were at home I'd go check my car...)
--DD
pbanders 05-19-2003 01:39 PM
Riveted. If they rotate, they're unreliable. The fix is to remove the backing material in solvent, solder all the riveted connections, then repot the back to prevent moisture ingress. Yucky job.
