On the main relay board in the engine compartment, is it ok for the round male conector pins to rotate slightly? Or, would that indicate a weak/broken solder joint?
TIA |
914 Geek
I believe that those joints are riveted, not soldered. I would be concerned about them rotating. (Hmm, if I were at home I'd go check my car...)
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Riveted. If they rotate, they're unreliable. The fix is to remove the backing material in solvent, solder all the riveted connections, then repot the back to prevent moisture ingress. Yucky job.
