-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Firewall Access to Engine Comp (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1114650-firewall-access-engine-comp.html)
Geo9146GT 03-13-2022 01:58 PM
Does anyone have a template for cutting an access panel thru the firewall to the engine compartment?
Thx
George
Emo993 03-26-2022 04:29 AM
George, I've seen all different sizes big and small. I can measure mine if you would like. Markhttp://forums.pelicanparts.com/uploa...1648294144.jpg
Emo993 03-26-2022 06:25 AM
Here's a picture of a larger one. Also more on pbase 914-6 GT.http://forums.pelicanparts.com/uploa...1648301095.jpg
Geo9146GT 03-26-2022 09:27 AM
Thanks, but that is not going to be big enough
I think I'll heed the advice I got from a 914World member who advised me to make it big enough to
remove the fan housing/alternator assembly through
George
Emo993 03-26-2022 11:55 AM
Hi George, I'm not sure I would do that. Your engine/fire wall is a very important part of the structural integrity. If your worried about the removal of the fan housing to remove/service alternator you can modify the fan housing to accomplish that without engine removal. Just my 2cents. Best, Mark
Dave at Pelican Parts 03-26-2022 10:14 PM
If you are making a large hole, you might want to reinforce all around it. And definitely make it fireproof!! Remember that there's a reason it's called a "FIRE-wall".
--DD
Maltese Falcon 03-28-2022 07:12 PM
I'm using a decent thickness 18 gauge sheet metal plate on my six. Also a bit of thin weather stripping foam rubber around the perimeter to keep any vapors out. Disregard the extra "Bump" at the upper left corner...only needed for some custom engine compartment accessory that I've added.http://forums.pelicanparts.com/uploa...1648519892.jpg
