Parts Klassik Wiring Harness
Can anyone provide wiring instructions for the 3 Pin CDI Wiring Harness for Pertronix (part number 911.612.050.PX) sold by Parts Klassik?
Old 06-06-2022, 06:13 PM
I need to know
(1) the purpose of the two red wires with female electrical fittings,
(2) the purpose of the two male spade electrical fittings.
(3) the installation of the long red wire
(4) the installation of the long black wire
(5) the installation of the long blue wire.
Also, how the red wire from the Pertronix module and the black wire from the Pertronix module are installed to work successfully with the wiring harness.
Old 06-12-2022, 12:34 PM
914 Geek
Have you tried contacting Parts Klassik for this information?
--DD
Old 06-13-2022, 02:30 AM
Yes. There are no instructions provided by Parts Klassik. However, I have a consultation scheduled with the person who designed the wiring harness. He is at Klassik Automotive Training School.
Old 06-15-2022, 05:15 PM
Here are the results of the consultation. The wiring harness sold by Parts Klassik is only needed if the current harness in your car is not functional and and the wiring harness wires are too short to be used in a 914 six. Here are the instructions for using the existing factory wiring harness.
The red wire from the Pertronix unit needs to be attached to a keyed 12 volt source. This can be found at Pin1 of the 14 pin connector which is 12 volt only with the key on.
The black wire from the Pertronix unit needs to be attached to directly to the black wire in the existing wiring harness where the points are connected.
Lauran
Old 06-18-2022, 12:31 PM
