1.7 D Jet no park issue
Hi, I’m getting frustrated with my 914 and a no start problem, I’ve checked the LT and HT side of the ignition and all tests good. I have a clean spark at the points when I flick with a small screwdriver and when I put the coil HT lead to earth and flick the points, but when I do exactly the same but using the key to turn the engine I get nothing at all ??? I’ve changed points/coil/condenser but no change. Engine was running fine last week and just decided to not fire up this week. HT leads are new too, I’ve also soldered a wire across the rotor to test and still nothing. I know it must be something simple but I seem to be going round and round with it. HELP PLEASE. Ta
Old 07-10-2022, 10:15 AM
Sounds like you don’t have power going to the coil when cranking. I would check that first.
Daniel
it's not leaking....it's just marking it's territory
Old 07-10-2022, 10:40 AM
I have power at the coil with ignition on, not sure about cranking so I’ll check that and report back.
Old 07-10-2022, 11:22 AM
914 Geek
Sometimes the ignition switch has a failure mode where it powers off the "switched power" circuits when cranking. Definitely check to see if there is power to the coil when cranking.
--DD
Old 07-11-2022, 03:28 AM
Dave and Zuffenwerker you are both right, I cranked the engine with voltmeter connected and it drops to less than 1 volt, so ignition on 12.5 volt and when cranking it drops to 0.6 volt, thanks guys but any ideas why this is suddenly happening and how to fix it ??
Old 07-11-2022, 09:35 AM
bowlsby's Avatar
Replace the plastic portion of the ignition switch. Only use the Porsche brand, avoid the aftermarkets switches.
Old 07-11-2022, 11:57 AM
Ok. I’ll give that a go. I’ll let you know how I get on
Old 07-11-2022, 01:05 PM
Sounds like a bad ignition switch. You could pull it out and do some testing with a meter to confirm. If the switch is not the culprit I have another theory but hopefully that’s it.
Daniel
Old 07-11-2022, 03:59 PM
Well I swapped out the ignition switch for a spare and turns out that it was the culprit after all. Thanks for your swift replies and diagnosis of the problem. I may have found the issue but it would have taken me weeks to narrow it down. Thanks again all.
Old 07-12-2022, 01:51 PM
Banned
i think @zuffenwerker is actually correct
Old 07-19-2022, 05:52 AM
