Haasman
914-6 No Power to license plate light circuit
In diagnosing my 914-6 that has no power to license plate light circuit.
I discovered that the #7 fuse block has no power. Isn't the headlight switch the source of that power?
Haasman
Old 07-16-2022, 07:14 PM
John Rogers's Avatar
It's the ground connection.
John
Old 07-16-2022, 08:12 PM
914 Geek
Original Six, or conversion? What year?
In the later four-cylinder cars, the headlight switch is the source of power for the license plate light circuit. I assume it's the same on earlier cars and Sixes, but I haven't really looked into it.
Do you have wiring diagrams for your car? Those would answer the question more authoritatively.
--DD
Old 07-17-2022, 02:38 PM
Haasman
It is an original 914-6. I do have a wiring diagram and see that the gray wire from #7 fuse goes up into the headlight switch.
I will double-check grounds.
Haasman
Old 07-17-2022, 08:32 PM
