Trans mount
Does anyone know how much you have to cut out of the brace that runs along the bottom of the rear trunk That hold the transmission mounts. I want to install on 915 in my 914. I don’t wanna make it too weak. I’m installing a 3.8 L 964 with a 915 trans that’s has the ring and pinion flipped with a wavetrack . It looks like you almost have to cut the thing completely out-of-the-way in order to get the engine tin up to be level and to seal the engine apartment. Any information is greatly appreciated, slammin out.
914 Geek
I have not heard of the cross-brace being cut at all! The 915 box is not, to my knowledge, that much taller than the 901-based 914 gearbox and does not require that sort of extensive modification. Double check the rest of your setup and your assumptions, because it sounds like something is badly off there!
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
dr914 ***********
don't cut it!!! Shim the mounts slightly
Has your 915 been converted to the 916 type of tailcone that mounts the same as the regular 914 transmissions? I've not heard of anyone doing anything else for mounting. Photos would help a lot to explain your situation.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Control Group
Measure twice and don't cut anything
She was the kindest person I ever met |
So using a 911 tailcone & mount; that is a challenge.
nothing to see here
There was a 914 6 conversion on BaT recently that had a 915 - some of the photos might be of use? https://bringatrailer.com/listing/1973-porsche-914-111/
dr914 ***********
we have done many 914-6 conversions and quite a few with the 915 gear box. The transmission has to have the mounts shimmed to clear the body
I'm running the 916 kit and did not have to shim or cut anything. I'm using the Wevo Blue mounts on the trans. Nobody that I know of makes the special tin for a 3.6 in a 914. You have to take 914-6 tin and modify it with the 993 tin. I did have to add spacers to my headers to push the muffler a bit back to clear the rear back up light switch.
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. |
