Which replacement soft brake lines needed
Hi everyone
It’s been years since I’ve done this job and I’m ready to tackle this again on my street car maintenance list
I want to replace my brake lines
Not certain which ones I need
The car is a 74
I “believe” the early and late lines sold are likely different in their attachments at the strut mounting tabs
This car has 911 front struts/3.5 spacing
And iron “A” calipers mounted
Rear brakes are stock 914 calipers with special pads/adj proportioning valve
Which soft lines should I order?
I assume 914/late for the rear
? Will 914 front lines mate/thread up to A calipers?
Thanks everyone
Brant
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 11-27-2022, 08:01 AM
Eric at PMB would probably have everything or tell you what you need.
Old 11-27-2022, 04:18 PM
g911's Avatar
I’ll second that. Holly in customer service was super helpful on my 73 caliper refresh and replacement rubber lines.
Old 12-02-2022, 10:52 AM
Cairo94507's Avatar
Eric Shea is the man for brakes and really most other things you might need on your 914 as they are now doing full restorations and custom builds. PMB is in Sandy, Utah if I recall correctly. Great guy.
'71 914-6 #0372
'17 Macan GTS
Old 12-03-2022, 06:24 AM
Emo993's Avatar
Yup Eric is it. FYI, I also have the same front as you, I moved my 914-4 fronts to the rear. No parking brake. My original stainless steel lines work fine for both front and rear.
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 12-03-2022, 12:56 PM
