10" oil cooler location?
I just parted a 75 914 with air and I noticed the air condinser under the spare tire ,and a big hole to feed it air, has anyone put their oil cooler their?
Old 05-29-2003, 07:31 PM
914 Geek
Yes, it has been done before. Ducting air in from the front and out the bottom is one way, putting a big fan on the cooler and getting air in the front 1/4 of the condensor hole has also been done.
--DD
Old 05-29-2003, 09:55 PM
I just did this with an RX-7 cooler.
I cut 2 rows of 4, 4 inch holes in the replacement sheetmetal of the floor of the front trunk. I used a sheet of 1/8 UHMW polyethelene to make a scoop in and a scoop out. The scoop in is under the front row of 4" holes and the scoop out is under the back row of 4" holes. The plastic makes an arch under the trunk where it is screwed tight between the rows of holes and has a 1" spacer at the front and back. It reduces the clearance by about 1.5"(between the front wheels so speed bumps are not a problem)
The RX-7 oil cooler is just the right length to sit over the front set of holes. It sits in a metal box which ducts the air up through it, and back down to the rear set of 4"holes and out the exit scoop.
Last years drivers ed temps were very high. Sense I installed this, The temp gauge is dead vertical; either on the street or track.
Some pictures would be worth a thousand words here. I'll see what I can do.
Old 05-30-2003, 05:17 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Old 05-30-2003, 06:09 PM
Banned
Old 05-30-2003, 06:12 PM
thanks steve, i'm builing a 2.7 type 4 for around the neighborhood,kymco has the cooler,fan setup with all the thermostats I like your idea alot
Old 05-31-2003, 07:44 AM
