Not right in the head
nutzforporsche's Avatar
Send a message via Yahoo to nutzforporsche
CSA Wheels
Does anyone know if the CSA wheels that fit a bug, fit the 914? Stupid question I know. They look like 4X130mm, but can't tell. I'm getting them for 200.00.
Thanks!
stevethacker@earthlink.net
87' 944S
99' BMW 740iL
Old 06-09-2003, 10:22 AM
914 Geek
Yes, but the offset is not very good for 914s--you can only fit 165s under stock fenders if you use Bug wheels. You can probably go to 205s if you have flares, though...
--DD
Old 06-09-2003, 11:06 AM
Dave,
My teener is eight inches wider with the rayco kit. So I can run up to a 9" wide wheel in the rear and a 7" in the front. So If you think the bolt pattern is good to go then I'm going to jump on these.
Thanks!
87' 944S
99' BMW 740iL
Old 06-09-2003, 12:54 PM
914 Geek
The later Bugs (disk-brake ones, I believe) with four-bolt wheels have the 4x130mm lug bolt pattern.
Sounds like you've found some wheels that will do fine for "rolling around". I think they'll be way too far inside the wheel wells for a car with that much of a wide-body, but they'll be better than 914 wheels from that perspective!!
--DD
Old 06-09-2003, 02:29 PM
When I get these babies mounted I'll post a pic. I think they are really sharp wheels. The offset brings them just under the lip of the rear wheel well. I'll have about 3/8 of an inch for play with the 50s on the back. The front is a little less than that.
87' 944S
99' BMW 740iL
Old 06-10-2003, 05:23 AM
