				Which replacement soft brake lines needed
			Hi everyone
				It’s been years since I’ve done this job and I’m ready to tackle this again on my street car maintenance list I want to replace my brake lines Not certain which ones I need The car is a 74 I “believe” the early and late lines sold are likely different in their attachments at the strut mounting tabs This car has 911 front struts/3.5 spacing And iron “A” calipers mounted Rear brakes are stock 914 calipers with special pads/adj proportioning valve Which soft lines should I order? I assume 914/late for the rear ? Will 914 front lines mate/thread up to A calipers? Thanks everyone Brant
			914/6 2.0S with twin plug all metal body panels 19quarts of oil 4 gallons of gas and 1826 lbs (wet) Last edited by Brant; 11-27-2022 at 09:04 AM..  |
			Eric at PMB would probably have everything or tell you what you need.
			Eric Shea is the man for brakes and really most other things you might need on your 914 as they are now doing full restorations and custom builds.  PMB is in Sandy, Utah if I recall correctly.  Great guy.
	'71 914-6 #0372 '17 Macan GTS  |
			Yup Eric is it. FYI, I also have the same front as you, I moved my 914-4 fronts to the rear. No parking brake. My original stainless steel lines work fine for both front and rear.
	1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover  |
