				Need advice moving & updating fuel pump
			HELP please
				-- currently have 1973 914 2.0L 3-port leaking fuel pump passenger side rear. Want to replace with new in-out fuel pump and relocate to driver's side front. Anyone have experience doing this and what should the new fuel line plumbing diagram look like front and rear?
	Indiana 300594, 300839, 301258, 350407, 68 911 Driver, 1968 911L SWT Sportomatic, 1970 911T Irish Green restored, 1974 911 Carrera, 1975 911 Carrera Used to drive kids to the pool in 356/1500RS Carrera Speedster 80820. Wife would leave it in the shopping center parking lot -- now in Porsche Factory Museum.  |
			go here, https://bowlsby.net/914/Classic/TechNotebook.htm
	scroll down to "technical ...".. you will then find hand drawn schematics. I have used the same when I moved my fuel pump (and changed to a 2 port config). the pump will go in the front on the passenger side. also the 914 brown handbook published by ***********/George hussy has a great technical DIY article.  |
			 914 Geek
			The two-port pump basically eliminates the "R" fitting which goes to a Y-shaped adapter in the middle of the hose that returns fuel from the fuel pressure regulator to the tank.  Get rid of the Y adapter and just run the return hose from the hard-line on the side of the engine bay to the hard-line through the center tunnel.
			--DD
	Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling  |
			 Zink Racer
			Check out Tangerineracing.com.  Chris makes a 2 port pump mount, has the specs on the pump, and the ss lines you should also put in the car if that hasn't been done.  He can "kit" up everything you need to make this projects as painless as possible.  I did all of this with his stuff and his technical support as well.
	Jerry 983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4  |
			You can use an Aritex E-8445 pump, available from FLAPS.   It is a 2 port direct replacement for the factory pump.
			Clay
	Clay Perrine 74 914 1.8L (Frodrick) 73 914 /6 4.0L 964 motor (Igor) 70 914 /6 Factory Six. (Elwood) 95 BMW 540i (Inga)  |
			Moving the pump to the front could be a greater safety risk depending on where it’s located.  The 75-76 cars put it under the tank which is not easy to retrofit mount and access it there.  Locting the pump in the front trunk spare tire well, a front end collision could also create a fire.  Also with the pump in the front trunk the fuel lines running in the center tuneel in the cabin are pressurized and the 75-76 cars used higher pressure lines than the earlier nylon lines.
			I use the stock pump in the stock location and have implemented the factory service bulletin P213 for it to prevent vapor lock. If the pump absolutely needs to be moved to the front consider the steering rack recess under the cover plate and be sure to change the fuel lines in the tunnel to new stainless lines.
			http://bowlsby.net/914/CanAm/ http://bowlsby.net/914/Classic/ http://bowlsby.net/914/WiringHarnesses/ http://bowlsby.net/914/PartsFS/ Last edited by bowlsby; 11-26-2022 at 07:38 AM..  |
			I believe our hosts here sell a direct replacement pump for the late model cars. Years ago I used to buy the original Bosch 69133 late model pumps on Amazon.
			The Tangerine Racing pump mount works well next to the steering rack, and there's a fuel lines package with everything needed to complete the conversion.
	Chris Foley CFR-Tangerine Racing Products, LLC - 914 Products and Services  |
			Source a 75-76 pump/filter access cover and a 2 port pump. You will have to cut a rectangle in the front bulkhead. The pump package is now readily accessible from the front trunk. You don’t have to climb under the car to address the filter.
	here? not so much i think. high five!!!  |
			Little off line but with carbs I moved mine to the front under new tank location, inline fuse, easy  access. Best, Mark
			1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover Last edited by Emo993; 11-26-2022 at 11:51 AM..  |
			Your workmanship looks great but I would be very uncomfortable with that setup.
	Is that a copper U-bend I see?  |
			![]() Why not mount your pump as the early 911 front pump location? ![]() I make up a front mount that locates off the steel crossmember..... ![]() This is certainly a safe location, and the hose routing can easily be worked out. I do not have a 914 available to test fit, but would be happy to work with someone who would like to try this. Please email me if interested: len.cummings @ verizon.net
