-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   914 windscreen washer - how does it work? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1139671-914-windscreen-washer-how-does-work.html)
MARCANNEKE 05-09-2023 12:46 AM
Hello,
I want to change the original windscreen washer ssystem on my 1971 Porsche 914.
If I put an elecrical pump on to the system, how can I activate this?
Can I do this via the existing button on the dash, or do I have to make an extra circuit to let the pump go when needed?
Thanks in advance for Your Answer,
Marc
Zele
Belgium
djpateman 05-09-2023 04:42 PM
I cannot remember the exact system used in 1970/71, but assume it had a water valve like the later cars. I made a switch housing and used a small switch to replace the valve. The switch activates a relay that activates the pump. A special disc I made replaces the air hose connection on the tank cap so that the cap is vented but relatively sealed. The pumps, similar to the 914/6, 911 & 928 are readily available.
Dave
phelix 05-14-2023 02:19 AM
Electric Windshield Washer Conversion 914
