914 windscreen washer - how does it work?
Hello,
I want to change the original windscreen washer ssystem on my 1971 Porsche 914.
If I put an elecrical pump on to the system, how can I activate this?
Can I do this via the existing button on the dash, or do I have to make an extra circuit to let the pump go when needed?
Thanks in advance for Your Answer,
Marc
Zele
Belgium
Old 05-09-2023, 12:46 AM
djpateman's Avatar
I cannot remember the exact system used in 1970/71, but assume it had a water valve like the later cars. I made a switch housing and used a small switch to replace the valve. The switch activates a relay that activates the pump. A special disc I made replaces the air hose connection on the tank cap so that the cap is vented but relatively sealed. The pumps, similar to the 914/6, 911 & 928 are readily available.
Dave
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 05-09-2023, 04:42 PM
nothing to see here
Electric Windshield Washer Conversion 914
Old 05-14-2023, 02:19 AM
Tags
pump , washer , windscreen
