BKOMAR's Avatar
Send a message via Yahoo to BKOMAR
Question Ford starter solenoid wiring
HELP! I used to have one of these on my car, but when I transplanted engines I didn't need it. Now I am having the starting problem again and I can't remember how to wire it up. I tried it a few months ago and ended up frying my points and condenser. I have an auto-X today and I need to get this thing wired up quickly and use it as a temproary fix until I can figure out the root problem. Can anyone tell me how to wire it up?? Thanks in advance, Brian
75 914 2.0L
73 914 2.0L X2
73 914 1.7L X3
71 914 1.7L
87 944S
1987 SAAB 900 Turbo
80 Euro 911SC
1980 Yamaha XT500
Old 03-16-2003, 07:25 AM
i can't draw a picture, but take a hot lead from the starters battery lead to a big post on the ford solonoid.
take your existing key wire from the starter to a small lead on the solonoid ( not sure which one , but it might say 'ing' on the solonoid. )
make a wire from the remaining big post to the key wire to the starter.
the solonoid must have the housing grounded well in order to work. if it is a marine solonoid, the second small post must be grounded.
when in doubt, smack it.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-16-2003, 09:55 AM
a little late and perhaps not the correct set up. hope this helps.
Old 03-16-2003, 10:09 AM
BKOMAR's Avatar
Thanks guys, I got her figured out this morning and had a great time at the Auto-X. It never ceases to amaze me that this 100hp car spanks cars with twice the hp. I was only 5 sec behind my buddies ~280hp, suspension done to the hilt, slick shod M3! To think what I could do with slicks! Those are on my shopping list! Brian
75 914 2.0L
73 914 2.0L X2
73 914 1.7L X3
71 914 1.7L
87 944S
1987 SAAB 900 Turbo
80 Euro 911SC
1980 Yamaha XT500
Old 03-16-2003, 04:17 PM
I put my engine back in last night but I get nothing from the starter. Can you guys please explain the wiring in this photo. I have a feeling I am making this much harder than it should be but I am lost here.
Ron
Old 06-09-2003, 10:36 AM
Ok looking again at the wiring diagram two posts on the starter. Battery and alternatoeon the long post and yellow wire from the relay board to the short post right? So what are all of the other wires in this photo running to?
Old 06-09-2003, 11:26 AM
914 Geek
The solenoid should have four connections. There should be an "input" and an "output" (I'm probably not using the "correct" names, but I hope I can convey the idea). And there should be two "switching" connections.
The "input" should be connected to the same post as the big FAT cable from the battery. It doesn't have to be that thick, but it should be big stout wire at least as thick as the stock yellow starter wire.
The "output" should be connected to the flag terminal on the starter where the yellow starter wire used to go.
Used to? Yeah, you unplug the yellow wire, and connect it to one of the "switching" contacts on the solenoid. You hook the other one of those to ground.
And that's how you wire up a relay--because a solenoid is just a big relay...
--DD
Old 06-09-2003, 02:36 PM
check the 14 pin at the relay panel also. make sure the yellow wire is hot with the key in the start position. smokem' if you got 'em
edit..... ronh, you have the stock set up. the photo shows a 'helper' solonoid.
Old 06-09-2003, 04:11 PM
I have good current coming from the relay board when I thrn the key. The "helper "solenoid is what ha me confused
Old 06-09-2003, 07:54 PM
