Oil temp and fuel level gauge issues
Would anyone have a photo of the back of an oil temp and fuel level gauge they could easily post showing the wiring and connections? My fuel level is not registering even with a new fuel sending unit, and my oil temp is not showing, either, even though the oil temp sending unit is good. Any other suggestions also appreciated. TIA!
Try grounding the oil sender wire either at the sender or the gauge. I should peg the needle if everything else is hooked up correctly. It just need a positive, ground and sender wire. |
Administrator
Jeff Bowlsby's Tech Notebook has a ton of good info in it, including this diagram:
![]() It's a good idea to bookmark his site and check it when you have questions like this. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
