-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Floor Pan questions (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/114516-floor-pan-questions.html)
urbanskater 06-11-2003 08:49 PM
Floor Pan questions
Sometime this weekend i am going to be grinding out the floor pans, i was wondering where the welds are so i can grind around them and then sand them down. Is that a good technique, if so can some one inform me as to where to start grinding
Bleyseng 06-11-2003 08:52 PM
The pans are spot welded mostly from the underneath. The crossbrace is welded from the top as are the seat brackets.
If you are trying to clean up the pans remove the tar sound deadening first with a heat gun. They put a wire brush on your grinder to remove all the old paint. Then grind out any rusty spots.
Geoff
urbanskater 06-11-2003 09:02 PM
ehh well the pans are rusted through for the most part, and we are getting new pans...anyhow are the spot welds a certain distance from each other?
sixbanger 06-11-2003 09:10 PM
I just had my pans done and I bought the left and right half pans.They aer I'm told a better fit when all is said and done.What pans did you buy left or right or front and rear???
THX
RT
urbanskater 06-11-2003 09:28 PM
*sigh* front and back, i was gonna buy the left and right from tweeks but they raised the price to about $300 and they failed to update it in their magazines. Nehow i went ahead and bought the front and back from PP, they were suppose to be here last friday, its now almost thursday, i was suppose to get a weld job tuesday but they never came, so now i am greatly pissed...someone can expect a phone call fairly soon. Will the front and back fit right? or will they be loose?
Bleyseng 06-12-2003 08:17 AM
If they are from PP they will fit right if you do all the prep work right. You need to use a spot weld cutter to remove all of the old pans. Cut out the spot welds first around the perimeter. You can see them after you wire wheel off the undercoating and paint.
Grind everything smooth and clean for a good weld and fit.
Drill 1/4" holes in the new pans every 4" to fill weld so the pans look halfway orginal.
Test fit and tack weld both pieces on before welding everything up.
Transfer the seat brackets to the new pans.
When you are done the pans will fit and look factory if you take your time.
It helps to get the car as high in the air as possible so you aren't on your back with the pans 2' from your face.
Geoffhttp://forums.pelicanparts.com/uploads/pans.jpg
