long wheel studs - why
Some race cars run the 100mm studs. Aside from making it easier to do fast wheel changes, is there a reason for the super long studs?
tia dr |
Long wheel studs actually make the wheel change a bit more cumbersome. The longer wheel studs allow the use of wheel spacers that allow the track to be increase as well as the use of wider wheel/tire combinations.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
Safety....the idea is that one can see that the threads are fully engaged with the nut.
also, if the nut's are loose, you'd have a few extra seconds to pull off the road/track before the wheel came off.
'73 914, 1.7, with Boxster transmission in the future?
All good answers. And, they look cool.
They are actually to mount "dual-eezs" when necessary.
Now that would take some serious GT flares!
depending on the kind of stud they are used for quick tire changes. The ones made specifically for that are just a shaft at teh end and the threads start about half an inch from the end. When using an impact gun you can go much faster.
Black 72 1.7 914 http://www.pelicanparts.com/gallery/Biggy72/ WSU Formula SAE Drivetrain team leader/ Suspension team http://www.mme.wsu.edu/~sae/ |
I have these super long studs on my car..
![]() And now, to reveal the 5 lug conversion so far!!!
"It'll fit?" See my V8 thread Pics of my car Hear it with Magnaflow mufflers and shorty headers Or just hear it with open headers ![]() Hear it current, No ugly tips. louder Incar ax vid. 4-2-05 7-16-05 SCCA auto x Stockton. <---------New! |
Although I might add that I have one problem.. I dont have any lug nuts that fit.. Where can I get them? All I have holding them on right now are 2 lock lugs.
ya those aren't for putting on lug nuts fast.
914 Geek
Just pick up some 911 lug nuts. Steel ones, they're open-ended. The closed-ended alloy ones obviously won't work.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
