pbanders's Avatar
Send a message via Yahoo to pbanders
Do you think this motor will fit in my 914?
I've been thinking about an engine conversion, this looks like the motor I've been looking for:
http://www.pureluckdesign.com/other/rta96c/index.htm
Do you think it'll fit?
Old 06-20-2003, 02:16 PM
Barber Dave's Avatar
Thumbs up Will it fit
Only if you can get along without the rear trunk!!!!!
Try it and post pictures of your progress.
Dave
Rennlist Member
S.M.O.G.
914 Club
M.V.R.P.C.A.
73,BLACK ,2.0
Old 06-20-2003, 02:29 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
I wonder if you can modify your D-jet to work on it?
--DD
Old 06-20-2003, 02:50 PM
Tonyakavw's Avatar
Send a message via ICQ to Tonyakavw Send a message via AIM to Tonyakavw
Actually it would make for a pretty decent power to weight ratio, on the order of a 350 HP engine in a 914 (the engine alone gives Power (watts)/lbs as 136, whereas a 350 HP engine in a 914 (~2000 lbs) gives 130 or so...
I think your center of mass might move up a bit. And good luck finding springs and a torsion bar for that much weight.
Another consideration is the tranmission. Probably not going to handle that kind of torque, not to mention the low RPMs.
The real question is, can it be turbocharged?
-Tony
Tony
70 914 EJ25 - Body by Karmann, Engine by Fuji Heavy Industries
Old 06-20-2003, 03:00 PM
scg scg is offline
scg's Avatar
You'll have to upgrade to turbo half-shafts...
Scott
74 914-6 2.7
Old 06-20-2003, 03:05 PM
Ron Meier's Avatar
Yeh, the tranny - how 'bout a 50 speed to take advantage of low rpm motor.
And you could mount it like the Indy Turbine cars.
Been spending a little to much time in the Phoenix sun?
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 06-20-2003, 03:39 PM
M. Hendrix's Avatar
This looks like a conversion for the pair of limos, the super-stretch could even keep the back seat!
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 06-20-2003, 04:35 PM
pbanders's Avatar
With half a million ft-lb of torque, I'm not sure I'll need a tranny. But it might be a bit slow.
Old 06-20-2003, 05:11 PM
norustscott's Avatar
It is turbo charged...it won't work...
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 06-20-2003, 05:58 PM
Biggy72's Avatar
It's a rice motor... you wouldn't do a thing like that would you?
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 06-20-2003, 06:49 PM
VARam1500's Avatar
Picturing one of those engines in any car reminds me of the Dodge Tomahawk. That was where they bolted wheels to a Viper 505 V10 and wound up with a motorcycle-like thing. This would be similar. It's not a question of whether or not the frame could handle it because the engine IS the frame!
'75 1.8L L-jet 914
Old 06-21-2003, 05:37 PM
