BCinSC's Avatar
Send a message via AIM to BCinSC Send a message via Yahoo to BCinSC
Link to discussion about timing advance, infamous +20HP claim on EBay
Was told there is an existing discussion about this "miracle" either here, on 914club, or Rennlist. Anyone know the thread off top of head?
'73 914 1.7L White aka Blanche
Old 07-12-2003, 08:34 AM
Ron Meier's Avatar
Jack your timing up to 38-40 degrees@3000 rpm - engine will run like a bat out of hell until it blows due to overheating.
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 07-12-2003, 09:33 PM
Bull****.
Advanced timing kills top end power! want dyno graphs to prove it?
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 07-14-2003, 12:20 PM
Ron Meier's Avatar
Ok Jake - you win, but what about the low end pulling power? High end power is no good in road racing.
Old 07-14-2003, 01:02 PM
well, thats why you buy a distributor that allows the initial advance to be set higher(the way it normally would be if the entire timing was jacked way up) and limit the top end advancve..
This way you get the best of both worlds..plus fully recurvable advance that can be reset in 5 minutes..
VERY soon I won't be using any VW distributors on my engines, solely Mallory, they rock and reallyn wake up my combos.
Jake Raby
Old 07-14-2003, 01:10 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Jake, Im curious how this is controlled. is it mechanical?
Old 07-14-2003, 01:37 PM
Yes, its a normal old distributor thats indexable and adjustable.... simple to do too.
Jake Raby
Old 07-14-2003, 01:56 PM
Do you have to change the weights in order to set the advance?
Old 07-14-2003, 02:04 PM
Nope.......spring changes and breaker plate changes do the trick....takes 5 minutes to make a swap.
Jake Raby
Old 07-14-2003, 02:07 PM
Sounds way cool, how much does something like this cost to rig up?
Old 07-14-2003, 02:11 PM
www.aircooled.net is the place to buy it...look under ignition.
Jake Raby
Old 07-14-2003, 02:16 PM
