How long should I wait after window installation to do water testing?
Lauran
Old 04-24-2024, 12:39 PM
I checked the window fitment in the car and have found that both the firewall and the glass are curved toward the back of the car as it should be. The upper edge of the firewall was positioned toward the front of the car in the corners. I used wood and a lead hammer to adjust the upper edge of the firewall in the corner area so that it is flush with the vertical mounting point on the car.
Lauran
Old 04-25-2024, 09:18 AM
Lauran
Never a 914 will rust if it gets wet also water will get into your engine bay
Old 04-28-2024, 06:09 AM
dr914 ***********
something is going on here Lauran, NO ONE has this much trouble installing a rear glass. SOMETIMES the frame area is warped and the glass does not sit flat against it due to a previous wreck
Old 04-30-2024, 09:40 AM
My third window installation using 3/8 inch butyl and glass primer on the glass failed.
I have water leakage along the bottom edge of the glass.
I am going to try it again using 3/8 inch butyl and without any glass primer on the glass.
Also no glass primer on the body of the car.
Lauran
Old 05-11-2024, 05:26 PM
My fifth try on installing the rear window using 5/16 inch butyl as done on May 12, 2024.
The air temperature was 67 degrees and the butyl temperature was 135 degrees
The window glass and frame of the car were washed with hot water and Dawn dish washing soap.
The both were rinsed with cold water.
Two setting blocks were stacked and glued in placed about 6 inches from each end of the glass.
A total off four setting blocks were used.
I used my thumbs to press on those areas where further contact with the glass was needed.
Duct tape along the bottom of the glass was used to hold the glass in place after it was put in place.
I water test the installation tomorrow
Lauran
Old 05-12-2024, 02:16 PM
Cairo94507's Avatar
I used Urethane to install my rear window. My previous install, almost 4 years prior had allowed the glass to come loose and it rattled. The Urethane was more complicated to install; I used one of the electric Urethane guns the windshield shops use and it pushed out more product than I wanted so we had to do some clean-up. But that window is in and it does not leak. If I were to do it again, I would cut just the very tip off the Urethane tube. Good luck.
'71 914-6 #0372
'17 Macan GTS
Old 05-13-2024, 06:30 AM
On May 13, I tested the window with soapy water and compressed air.
There were no leaks.
Thanks to all for their suggestions.
Old 05-13-2024, 01:20 PM
Cairo,
Is the Urethane applied to the glass or the mounting perimeter on the car before the glass is installed?
Lauran
Old 05-15-2024, 11:27 AM
