In Search of a Fuel Screen
Does anybody know of a source for a new fuel screen for a 74 914?
I don't see one on the Pelican parts list.
Also, Where exactly is the fuel screen & how do I get to it.
Thanks,
Vern
Old 06-24-2003, 08:06 PM
Ron Meier's Avatar
If it has one it will be in the fuel tank over the suction line.
If it doesn't have one, buy a fuel filter and place it PRIOR to the fuel pump.
Case solved!
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 06-24-2003, 09:22 PM
Just so I understand, Are we talking "inside" the fuel tank?
That's how it was on other cars of mine but nothing seems simple on a 914,
Old 06-24-2003, 09:49 PM
Ron Meier's Avatar
Yes and since the fuel lines enter the bottom of the tank, I doubt there is one unless you can get your hand thru the fuel level sending hole.
Just put a filter prior to the pump on the suction line. This is the normal location on the cars I've owned.
Old 06-24-2003, 10:53 PM
Heres the part number for it; strainer sock
70-74 111-209-147
75-76 113 209 147
See if pelican can special order it for you. If not AA has it then.
You need to pull the tank and remove the feed line head at the bottom of the tank to access it. The bolt is at the bottom, attaching the feed tube.
Old 06-25-2003, 03:54 AM
Ron Meier's Avatar
Glad someone knows.
Old 06-25-2003, 06:03 AM
Wink
Pelican did not have em.
I gots mine from http://www.AJUSA.com but you have to call them. They have most parts AA has.
I have heard its tha same as the VW BUG screens
http://www.bfyobsoleteparts.com/oldsite/ass40.html
shows the same numbers. So its possible your FLAP could have it.
Of course you could call AA, but remember, for the next 30 days when your driving around and see another 914 you must call out...UNCLEAN!....UNCLEAN!
-Rich
Old 06-25-2003, 08:59 AM
vwparts.com also has them. Also check drivewire.com.
01 New Beetle 1.8t w/an attitude
Old 06-25-2003, 06:34 PM
bernbomb914's Avatar
The vw part that I bought did not fit. it was to big to go into the tank.
Bernie
May all your shifts be true
Chrome Yellow 74 1.8 Beauty
black 74 1.8 project car
2002 Land Rover Disco
2002 Astro Van
32' motor home
Old 06-25-2003, 10:08 PM
bowlsby's Avatar
Your local porsche dealer should carry them.
Old 06-26-2003, 07:28 AM
