cylinder head smog injector problem
we have a 912 e with a stripped smog injector. Does anyone have a simple (okay- patch job- the client can't afford to take the heads off) solution? The threads are really down in there and the oe air injector just spins around in the hole now
Thanks! |
Air pressurize cylinder with piston at tdc (both valves closed). Drill for helicoil (air pressure will blow cuttings back in your face) - use heavy grease on tap to capture "shards". Aluminum shavings will probably vaporize at combustion temps anyway (1400-1600 degrees).
OR JB Weld it in. |
we'll see if we can get a tap in there- long ways under the sheetmetal
thanks |
TRE Cup,
That sounds like John's car (silver-blue E). Ron, That is what I like about the board, smart folks giving great advice...http://www.pelicanparts.com/support/smileys/wat6.gif |
Thanks Coldbass (ale - mmmmmmmmmmm)
Not smart, just years of fixing broken race cars at the track in the heat and dirt. |
The car is a black E with electric windows, tan full leather, Carrera front suspension, polished 7 x15 fuchs all around, H4 euros, fogs, sunroof, dual power mirrors- yep some mods came to her over the years!
The JB weld has set in over the long weekend, and so far so good thanks again db |
| All times are GMT -8. The time now is 02:10 PM. |
