Banned
Alfred1's Avatar
Liquid Wrench?
Is this stuff still available? Is there a better product for loosening seized fasteners? Also, does anyone know where I could get a "breaker bar" extension that would fit the handle of my Craftsmen 1/2 drive ratchet?
Thanks,
Alfred
Old 07-05-2003, 11:48 AM
914 Geek
Liquid Wrench is still available at many auto parts stores. Alternately, look for PB Blaster or Aero Kroyl. They are supposed to be better penetrating oils.
I often use large box-end wrenches as extensions to my ratchet handle. If not, get yerself to wherever you buy pipe and get a three-foot length of galvanized pipe about 1/2" ID. Or however big it needs to be to slip easily over the handle.
That and a BFH should work quite well...
--DD
Old 07-05-2003, 12:31 PM
Banned
Alfred1's Avatar
Thanks Dave.
Old 07-05-2003, 12:36 PM
Biggy72's Avatar
I use the handle on my floor jack alot as a breaker bar.
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 07-05-2003, 01:57 PM
jkeyzer's Avatar
I use the jack handle as a lever a lot too. But I also bought a set of two breaker bars from Harbor Freight for about 12 bucks.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 07-05-2003, 04:44 PM
Banned
Alfred1's Avatar
Thanks Jeff. Those Harbor Freight bars were exactly what I was looking for.
Alfred
Old 07-05-2003, 07:47 PM
mikester's Avatar
Send a message via AIM to mikester
I use my jack handle as a breaker bar too.
Careful though, I've easily broken bolts with it.
-The Mikester
I heart Boobies
Old 07-05-2003, 10:59 PM
I found an old can of AeroKroil when I was working on my old '70 914. That's the best stuff I ever used. A little spray, wait a few minutes, and the exhaust and sheetmetal fasteners just came out as if they had *not* been in place for over 20 years.
If you can find it, get a can...great stuff!
Old 07-08-2003, 06:46 PM
TGM TGM is offline
PB Blaster is great stuff and they carry it at Wal Mart
Old 07-08-2003, 08:26 PM
grind weld build
sean_V8_914's Avatar
if possible, apply heat to the nut. the expansion and contraction breaks the corrosion hold. heat will also enable the wicking action of the penetrant. Being willing to walk away for a few minutes to allow the heat and oil to work also helps.
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 07-08-2003, 10:31 PM
