Is Wire Size Critical for a Temperature Sending Unit?
Last week I mounted a VDO oil temperature gauge in my 914 and earlier today installed the VDO sending unit in the sump. I have some 12 gauge stranded wire which is too large to fit the clip on adapters on each end. If I trim the wire on the ends will this be ok or will the larger wire cause the gauge to read wrong? IOW should I use a smaller diameter wire?
No. It's simply measuring impedance (or is it resistance?) and is very low amperage. The factory wire (0.5mm2) is roughly equivalent to 20AWG.
1992 968 Coupe 1974 914 2L street car 1974 914 2L race car |
