Tail Shifter Clinic
I am hosting a 914 tail shifter transmission clinic at my home on Sunday, 7/20, at 8:00 a.m. If you plan to attend you must RSVP I want to be sure we have enough to eat and drink.
Join in or just watch the local 914 gurus solve this transmissions vagueness and the unwillingness to select all the gears all the time. tedmyrus@san.rr.com |
canna change law physics
Yep, let's see if we can get all gears.
James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Hi Ted, I'm game for any clinic on these cars......count me in!
Oh! I still have not been able to locate a R side exterior door handle, maybe James or one of the other local guys has one........nobody wants to give them up?
75' 2.0 w Ljet "I like the way she doesn't move in the curve's... and then she let's go!" |
We'll be there. This is another great chance to see what is involved with making a poor tranny into a great (?) one. All the 914 drivers in SD should attend.....
You classify Red Beard as a "driver"?
"Inventor - Blue Flame 914 Seat Heater" "Yellow Rusty Cars Are Faster" _____________________________ '70 2.5 (I'll never finish it - Somewhere over the rainbow.....,) '73 2.0 (Just Not The Same) '74 2.0 (Heartless & Lungless) |
Nope - I'm a "Guru"....
You may approach, chela....
Bump!
He may not be a hell of a driver, but James put the 'goo' in guru.
(that may not have come out quite right, or did it?)
Herb '72 Tangerine 'Teen 2.4 liter aluminum handgrenade |
Hmmmmm
Goo? Ted's Car is now road running. I need to get the pictures from the photographer (John Rogers), but the linkage was definitely out of alignment. Next, tuned the 36mm Dells. Then, after the fuel pump died, replaced the fuel pump Run up and down the street, and the cluth was dragging. A little adjustment and the car is actually running very well. It needs a bunch of TLC, but it is certainly worth resurrecting. James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 Last edited by red-beard; 07-20-2003 at 09:17 PM.. |
A BIG thanks to James!
You are welcome, and tell your wife thanks for breakfast and lunch.
James
