MiamiTurbo
Oil level cold too high
Had my oil changed at a local high end car shop. Not Porsche specific but lots of nice older cars. Been noticing lots of white smoke on startup and today I thought to check my oil level and found it quite higher than the upper mark.
Should I try and siphon some out with a fluid extractor? Or just drain it and put new oil in? ![]() Sent from my iPhone using Tapatalk
wanabe911 owner 1974 914 2156cc project 2005 Lotus Elise Original owner 2002 996TT Tip |
MiamiTurbo
Anyone?
Looks like aprox 1 quart overfilled . I would drain or suck out a 1/2 quart and drive it and check again . Checking the oil after sitting overnight gives the most accurate reading.
Did the car smoke before the oil change ? Were you running synthetic or conventional oil before ? And what did they put in ? |
MiamiTurbo
Didn’t smoke before.
Sometimes after sitting for a long time it would smoke a bit on startup. Conventional oil before change and after change. Sent from my iPhone using Tapatalk
Control Group
Drain some out, maybe ask them about it
She was the kindest person I ever met |
MiamiTurbo
Thank you I think I will ask them about it.
914 Geek
Generally, up to a half-quart over is not regarded as a problem. A full quart over might be.
If you've got an easy way to do it, just siphon out a half-quart or so and see how it goes. Make sure to take a sniff of the oil, though. If it smells strongly of fuel, the oil is diluted and you should not drive the car any more until you change the oil and figure out how the fuel is getting in there. (It's often caused by a very very rich mixture.) --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
MiamiTurbo
Looking up the invoice, I actually had it in for a new clutch cable.
They added 4 quarts of 20w50 dino oil and a Wix 51085 filter. Here is the best part. I thought this was recently, it was actually 12/9/24! And if my odometer is correct I have driven it 170 miles in that time. My car has dual carbs that were rebuilt when I purchased it. Sent from my iPhone using Tapatalk
MiamiTurbo
So I checked my owners manual and it says 3.7 quarts or 3.2 quarts
My engine was a 1.8 When I had it rebuilt we made it a 2056cc How much oil should I add when changing my oil? Sent from my iPhone using Tapatalk
Does the manual say 3.2 without filter change and 3.7 with filter change ? When the engine was rebuilt was anything added like an extended sump or oil cooler ?
MiamiTurbo
That’s what I thought it said should have taken a picture. No extended sump or external filter.
Change the oil/filter and add 3.5 quarts . Run it then let it sit overnight . Check the level next day and add as needed .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
MiamiTurbo
Hats good advice thank you very much. Will report back.
914 Geek
Does the oil smell like gasoline? If so, you've probably got a carb problem that is dumping raw fuel into one or more cylinders. Find and fix that problem before driving the car. (And change the oil regardless.)
--DD
MiamiTurbo
I’m going to check that today.
MiamiTurbo
Oil smells slightly of gasoline
914 Geek
Slightly is OK, and expected of carbs.
Carry on. --DD
MiamiTurbo
Carry on I shall. Thank you!
MiamiTurbo
Changed oil. Changed filter. Added exactly 3.5 quarts. Took a short drive. Parked it.
Checked oil this morning and it’s over the second line. Took a picture but the oil is so clear it doesn’t show on the picture. ![]() Sent from my iPhone using Tapatalk
MiamiTurbo
Here
