Question Decel Valve --- Where is it mounted?
Considering that I've owned this car for about 5 years, this is really going to sound stupid, BUT where is the deceleration valve supposed to be mounted. Mine had been just sort of tucked away, but when I replaced my fuel lines I moved hoses around and found that it was just dangling. There's a mounting bracket on the valve, but I don't see any particular place to mount it.
Thanks for the help.
Howard
Old 07-15-2003, 02:55 PM
RustyWa's Avatar
It's mounted on the MPS bracket using one of the fasteners securing the MPS.
Eric
'75 914 2.0L - Sold!
Old 07-15-2003, 03:24 PM
AZ914's Avatar
On a similar note. what the hell do you plug into the DECEL valve / from where etc? Like Howard, mine was just dangling and only one hose plugged into it. I've heard its not really necessary but want to do it right if I can.
Thanks,
Jason (AZ914)
75 Malaga Red 914/6 3.2
Old 07-15-2003, 03:51 PM
RustyWa's Avatar
On the '75 2.0s...one larger connection on the top side of the air filter housing and then there is two (one small, one big) on the air plenums side just under where the MPS hose connects.
Other years better check the schematics on this site.
Eric
Old 07-15-2003, 04:06 PM
RustyWa's Avatar
Here's a bad photo...
Eric
Old 07-15-2003, 04:10 PM
Eric:
First ----- Thanks for the reply. I wondered if that was where it was supposed to be mounted, but the body of the MPS seemed to interfere. Now that I know that it's the right spot, I'll figure out which screw to use.
Second --- Holy *****. Nice engine. Everything really looks great. Maybe someday.
Howard
1974 914 2.0 "pearl" white
Every so often, I even get to drive it!
Old 07-15-2003, 07:33 PM
RustyWa's Avatar
Thanks. That's an old photo when it was pretty ratty. Here's a more recent photo plus you can just see the decel valve at the bottom of the photo.
Eric
Old 07-15-2003, 08:48 PM
AZ914's Avatar
Eric,
Thanks for the pictures! Well, that explains the gaping hole that I have in my air cleaner box!
Jason (AZ914)
Old 07-16-2003, 09:00 AM
