Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Type-5 powered 914
Well I was thinking of going with the Mazda Kzle motor but after looking at all the plumbing and a KEP adapter , I tacked,and am going for the Type-5 Oxyboxer. A little Sheetmetal fitting looks alot simpler than running all those coolant lines. A FAT 911 Shroud and a Pair of 44 IDFs. 2130 cc. and lighter than the type-4. Steve
Old 07-19-2003, 07:56 PM
skline's Avatar
Ok Steve, I am at a loss. What is a type 5 Oxyboxer? Fill me in.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 07-19-2003, 09:31 PM
Banned
See:
http://www.gearheads.dk/oxyboxer.htm
Old 07-19-2003, 09:38 PM
mike mueller's Avatar
If I read that site correctly, it's basicly a Type IV engine case fitted with VW Bug Type I heads on it???
I like the idea of watercooled heads, too bad the Wasserboxer heads have the exhaust in the "wrong" location for our 914's.
'73 914, 1.7, with Boxster transmission in the future?
Old 07-19-2003, 11:15 PM
Banned
Its a Vanagon watercooled motor that is converted to air cooled.it uses Air cooled heads. I am going to use Type-3 heatexchangers and Dansk Type-3 mufflerhead pipes set up and a 911 twin inlet single out let.This Motor allows you to use all the type-1 performance parts. 130 hp is no problem with these motors
This photo shws one installed in a bug for a 914 the cooling tin would be similiar. Steve
[Steve, leave out the spaces in between the "img" tags and the location. --DD]
Old 07-20-2003, 07:32 AM
Send a message via AIM to RD Evans
Question Price Estimate
Steve, what does the price look like for this engine?
Steve--
I've been looking at the same option and on paper it looks like a good performance/cost ratio. Do you know if there are any engine-mounting issues? Another consideration would be the need for a custom exhaust. One more benefit I can see is that it would make installing a T1 turbo kit a viable option On the down side, I doubt if it would be PCA legal..
Regards,
BWB
Old 07-20-2003, 09:50 AM
Banned
The exhaust is not a real big deal by going with the T-3 set up the down pipes are flanged to match a Stock two inlet muffler this is where I am going to go two into one then back to a 911 muffler. The stock 2.0 cross bar looks like it will fit. I may change to the early motor mounts in place of the 73 style and solid mount the motor to the 73 bar. Steve
Old 07-20-2003, 10:49 AM
Banned
Thanks to Piledriver and Tuna we have Photos.
http://www.tunacan.net/wasserboxer/914/
Old 07-21-2003, 08:54 PM
I'm doing a T-5 engine right now....
I'm developing mine for high torque in heavy applications, but not for a 914.
The T5 requires ALOT of custom work, and without a lathe and a Mill don't attempt it.
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 07-27-2003, 11:41 AM
