breakerless ignition module/setting timing
mybuddy bought oneofthese and the guy at
*********** said the 1.8 timing should be set at 27.5 degrees TDC @ 3000rpm. Themanuals say 7.5 degrees TDC @ 900 rpm. Who is right? anyone knows the correct answer ? Can you trust those AA guys ? |
The manual is correct if he still has the stock distributor on his 1.8. The other figure is for the stock distributor on a 1.7 or 2.0 engine.
I wouldn't trust AA. Then again, I wouldn't trust me either!! The factory manuals, however, I would trust for the most part. --DD |
Mine is at 27 and that is what most people say to set it at.
Oh, Mine is a 2.0
Thanks guys....he has a stock 1.8 so I guess his timing is set wrong....might cure his stalling when coming to a stop when he sets it right...itshocks me that its starts right up without a problem
Damn AA .....they knew he had a 1.8 ...does AA stand for anything else ? Think those guys drink brew and sell molested parts onebay all day....
just kidding Thanks again |
I have a 1.8
The timing from what I've read is set at the 900 rpm. The 2700 if for the D-Jet engines. |
| All times are GMT -8. The time now is 02:10 PM. |
