Carb Identification
Hi, Im Chris, I'm a lurker and an Ebay addict.
This forum has begun to cure my first problem. Great info and thank all of you who un-selfishly contribute.
I've had the 914 jones for about 33 years, and 3 years ago took the first step to a cure.
Today I decided to clean up the engine compartment and install a crankcase breather. One thing led to another...
Since I had the car I've tried to figure out what kind of carbs these are.
Please help ID these, and I promist to lurk no more.
Much thanks in advance,
Chris K.
Old 08-10-2003, 04:58 PM
skline's Avatar
It looks like an old Solex carb. I have a set of old Dellorto carbs that look similar but the filter bases are integrated into the carb and the one here it is not. Good luck.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 08-10-2003, 06:25 PM
Ron Meier's Avatar
Are they 1 barrel or 2 barrel - they look like the Weber/Holley/Solex 2 barrel progressives.
When I get to the office on Monday I will look for a sample "look alike", but based on the number on the base I would say Holley. Fitted to Pintos and a few thousand other cars.
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 08-10-2003, 07:09 PM
914 Geek
This is a single-barrel carb, which would have been mounted in pairs. Note that it sits on top of a manifold that sits directly on the head, not on a center plenum like the "Pinto Weber" does.
I'd guess Solex or Kadron (which is also Solex). But it really is a guess.
--DD
Old 08-10-2003, 09:35 PM
Ron Meier's Avatar
Ok Dave, your eyes may be better than mine, but I see two throttle shafts and two venturis in the pix showing the return spring. Plus, it is a square base carb and if you look at the manifold, the carb sits on a common plenum and splits to the cylinders from there.
The singles I've seen do not have a square base.
Old 08-10-2003, 09:55 PM
DuckRyder's Avatar
Send a message via AIM to DuckRyder
Looks like a 32/36 Weber (or clone there of) progressive to me.
Note that if it is dirty inside they are very nearly impossible to clean out.
Didn't someone make a dual progressive kit "back in the day"?
Robert
1975 Porsche 914/4-2.0
1972 Ford F100 Ranger XLT
2006 Ducati Sport 1000
323i.net
RangerXLT.com
Old 08-11-2003, 07:32 AM
Ron Meier's Avatar
The number on the base of the carb is a Holley List Number - R 7760.
Translates to Model 5200-C, 1973 Pinto 2 Liter, all trans, Economaster. The renew kit for it is Holley # 3-716
It is a 280 CFM, 2 barrel progressive carb.
Old 08-11-2003, 07:46 AM
914 Geek
DOH! I totally missed the second throttle shaft.
And yes, someone did make a kit to put two of these carbs on a Type IV motor "back in the day". It didn't become wildly popular, though.
--DD
Old 08-11-2003, 09:01 AM
