-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Plug wires to distributor cap wrong?? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/122945-plug-wires-distributor-cap-wrong.html)
914zim 08-11-2003 01:58 PM
Hey guys:
I tried to be really careful when I replaced my plug wires, paying close attention to which wire went where on the distributor cap.
When I went to put the cap on, I needed to rotate it 90 degrees to get the 2 clips attached, which got me thinking... Does this mean I have them connected wrong?
If I'm looking at the cap on the distributor. which is #1, #2, #3 and #4?
I know the firing order (from Haynes), but I'm not sure if it matters how the wires connect to the cap. Please help this newbie out!
Thanks!!:confused:
Dave at Pelican Parts 08-11-2003 02:24 PM
The cap is keyed so that it only goes on the distributor one way.
When the distributor driveshaft is installed in the correct orientation, the left-front cap tower is for the #1 cylinder. (Note there is a thin line in the distributor body toward the left-front--this scribe line indicates #1.) The right-front is #4, the right-rear is #3, the left-rear is #2. The distributor turns clockwise, and the firing order ("Zundfolge") is 1-4-3-2.
I'm more visual, so I remember where #1 is and that the left-side wires cross while the right-side wires don't.
--DD
914zim 08-11-2003 04:36 PM
Hey, thanks boss!!
I appreciate it.
