-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   running out of electrical problems (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/123044-running-out-electrical-problems.html)
ruddyboys 08-12-2003 06:39 AM
Here is a problem that has bugged me since I was able to get the car started. If I hook up the tach the car wont start. With all wire connected (Yes I checked if they were connected correctly) I turn the key and I loose all power and have to diconnect the battery for a few seconds to regain it. With the black/purple wire to the coil removed the car cranks but wont start. With the black/purple and red/white wire removed from the tach the car starts every time. I bought a new used tach and get the same results.
skline 08-12-2003 07:54 AM
It sounds to me like you have a dead short somewhere. That is how I used to wire ignition kills. Ground out the distributor and it will never start. Check for ground on your wires.
SGB 08-12-2003 08:24 AM
bad Coil?
