ruddyboys's Avatar
running out of electrical problems
Here is a problem that has bugged me since I was able to get the car started. If I hook up the tach the car wont start. With all wire connected (Yes I checked if they were connected correctly) I turn the key and I loose all power and have to diconnect the battery for a few seconds to regain it. With the black/purple wire to the coil removed the car cranks but wont start. With the black/purple and red/white wire removed from the tach the car starts every time. I bought a new used tach and get the same results.
74 LE "Bumblebee"
03 Jetta Wagon
Old 08-12-2003, 06:39 AM
skline's Avatar
It sounds to me like you have a dead short somewhere. That is how I used to wire ignition kills. Ground out the distributor and it will never start. Check for ground on your wires.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 08-12-2003, 07:54 AM
SGB SGB is offline
SGB's Avatar
bad Coil?
-Scott
My gallery page
Old 08-12-2003, 08:24 AM
