-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Forced induction (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/123280-forced-induction.html)
ViolentBlue 08-13-2003 02:09 PM
Forced induction
well I helped a buddy do a engine swap into a toyota corola, j-spec superchared engine, since then I've been bitten by the supercharger bug.
How do these engines hold up under forced induction, approx 8lbs.
I'm wrangling a deal on a supercharger right now, looks like I can pick it up for a song, originally designed for 1.6L engine, my aplication is a stock 1.7l 914 engine with a lumpy cam, bolted to a 901 from a 911 and stuffed in my VW beetle.
engine is brand new rebuilt, so its not like we'll be stressing a high miler.
it also will be running an apropriate sized intercooler, mounted above the tranny with electric fans encouraging air flow.
thoughts comments etc.
http://www.3sgtemr2.com/scage/beetle...IMG_0302sm.JPG
sammyg2 08-13-2003 03:22 PM
Your engine will handle 8 psi boost without any problems as long as you keep the timing under control. I ran mine at 7 psi all the time with no problems and you won't have the added back pressure of the turbo to deal with like i did.
Lumpy cam, heh? I hope the overlap and duration are not too high. If they are some of your pressurized air and fuel will end up going out the exhaust before it gets a chance to burn. A good rule of thumb is 270 degrees max.
if you are going to use the stock fuel injection you will have to design some sort of fuel enrichment system when under boost.
ViolentBlue 08-13-2003 03:29 PM
It'll be getting a megasquirt FI system, Map sensored so boost won't be a problem
p914 08-13-2003 04:10 PM
Forced Induction.... Is that anything like a shotgun wedding?
http://www.pelicanparts.com/support/smileys/pc2.gif http://www.pelicanparts.com/support/.../pimpflash.gif http://www.pelicanparts.com/support/smileys/mgwhore.gif
Nice bug!
Andyrew 08-13-2003 05:59 PM
8 lbs of boost for a vw type supercharger? That must be one heck of a supercharger!
M. Hendrix 08-13-2003 06:44 PM
ok so where is the 2.0 version of that blower?
M
ViolentBlue 08-13-2003 08:23 PM
actually the supercharger is off a J spec toyota engine, roots style
Dave at Pelican Parts 08-14-2003 08:25 AM
There's a guy over on the Shoptalk Forums BBSes (http://www.shoptalkforums.com) who goes by the name "Moggy". He's in the UK, but he has done what you are talking about. You might want to take a look over there and see what he has to say and look at the pictures he's posted.
--DD
