ViolentBlue's Avatar
Send a message via ICQ to ViolentBlue
Forced induction
well I helped a buddy do a engine swap into a toyota corola, j-spec superchared engine, since then I've been bitten by the supercharger bug.
How do these engines hold up under forced induction, approx 8lbs.
I'm wrangling a deal on a supercharger right now, looks like I can pick it up for a song, originally designed for 1.6L engine, my aplication is a stock 1.7l 914 engine with a lumpy cam, bolted to a 901 from a 911 and stuffed in my VW beetle.
engine is brand new rebuilt, so its not like we'll be stressing a high miler.
it also will be running an apropriate sized intercooler, mounted above the tranny with electric fans encouraging air flow.
thoughts comments etc.
a few pics of my project
Old 08-13-2003, 03:09 PM
Unregistered
sammyg2's Avatar
Your engine will handle 8 psi boost without any problems as long as you keep the timing under control. I ran mine at 7 psi all the time with no problems and you won't have the added back pressure of the turbo to deal with like i did.
Lumpy cam, heh? I hope the overlap and duration are not too high. If they are some of your pressurized air and fuel will end up going out the exhaust before it gets a chance to burn. A good rule of thumb is 270 degrees max.
if you are going to use the stock fuel injection you will have to design some sort of fuel enrichment system when under boost.
Old 08-13-2003, 04:22 PM
It'll be getting a megasquirt FI system, Map sensored so boost won't be a problem
Old 08-13-2003, 04:29 PM
p914's Avatar
Forced Induction.... Is that anything like a shotgun wedding?
Nice bug!
Old 08-13-2003, 05:10 PM
Andyrew's Avatar
8 lbs of boost for a vw type supercharger? That must be one heck of a supercharger!
Old 08-13-2003, 06:59 PM
M. Hendrix's Avatar
ok so where is the 2.0 version of that blower?
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 08-13-2003, 07:44 PM
actually the supercharger is off a J spec toyota engine, roots style
Old 08-13-2003, 09:23 PM
914 Geek
There's a guy over on the Shoptalk Forums BBSes (http://www.shoptalkforums.com) who goes by the name "Moggy". He's in the UK, but he has done what you are talking about. You might want to take a look over there and see what he has to say and look at the pictures he's posted.
--DD
Old 08-14-2003, 09:25 AM
