914zim's Avatar
Bursch exhaust questions
Hey guys:
A Bursch exhaust came with my pile-o-parts with my car.
It says 914 73-74 on the sticker, but it doesn't look like it'll
fit my car (76). It's got 2 inlets on each side and there is only 1
outlet on each side on my car.
It looks like a really good setup that would look cool on my
car, but I'm not sure I could make it work. Any ideas??
My current setup has a resonator and a muffler and it looks
like crap (rusty). The Bursch setup only has 1 muffler (I think).
I'm also wondering what emissions issues one might have with
this arrangement if I could put it on my car.
Any info on this would be appreciated.
Thanks!!
'76 914 Black/Black
VIN:4762900785
Old 08-15-2003, 07:54 PM
M. Hendrix's Avatar
You'd have to change over to an early style heat exchanger setup, or go with headers.
Honestly, you should change over to the early style if you don't have special emissions to deal with, it opens up more possibilities than just the Bursch, and it looks like you could use the heat.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 08-15-2003, 08:23 PM
914 Geek
Passing emissions depends on what kinds of standards you have to meet. If they have a visual inspection and require the catalytic converter and/or EGR to be in place, the older-style exhaust will not pass. If the emissions numbers they allow are noticeably lower for your 76 than for the 74, there's a good chance you will not pass the "sniffer" test by using the older-style exhaust.
Note that, if you change over, you will make a little more power. You will need the 73-74 2.0 style heat exchangers, that Bursch muffler you have, and the 73-74 2.0 muffer hanger. Plus, if you want heat you will need the pre-75 heater hardware; almost none of the 75-76 stuff interchanges with the earlier heater hardware.
--DD
Old 08-16-2003, 06:25 PM
914zim's Avatar
Thanks for the replies guys...
from other BB...
"Make sure which Bursch you have. If it just says "73-74", it is probably for 1.7-1.8 HEs. The 2 litre exhaust usually has a sticker that says, "73-74 2.0"....
Aw CRAP!
I just did a double check and it does NOT say 2.0L anywhere on the sticker. Does this mean that I can't even use this even if I changed to the earlier HEs? Man, that would suck!!
Thanks again guys.
'76 914 Black/Black
VIN:4762900785
Old 08-17-2003, 03:17 PM
914 Geek
Well, you could if you switched to 1.7/early 1.8 stuff... I'm not sure how you tell the difference on a Bursch, though.
--DD
Old 08-17-2003, 07:57 PM
Ron Meier's Avatar
The 1.7/1.8 has a smaller diameter pipe than the '73-'74 2.0. There is a definte pitch up in the pipes near the ends on the 1.7/1.8. I beleieve there is also a slight difference in the flanges. If you want I can measure the pipe diameters and shoot the flange end of the HEs and post them. Might help - won't hurt
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 08-17-2003, 11:17 PM
914 Geek
Hmm... The muffler flanges should be a different distance apart on the 2.0 than on the 1.7/early 1.8 as well. I don't recall which is larger or smaller, but they are different. (As Apoplexy found out when she tried to fit my 2.0 Bursch onto her 1.7 exchangers.)
--DD
Old 08-18-2003, 09:35 AM
