-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Recognize this Exhaust System? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/125276-recognize-exhaust-system.html)
BGman 08-29-2003 07:35 AM
First of all I would be remiss in not telling everyone thanks for the great BBoard. I have been a lurker on this board for several years and can usally find the info I need by searching previous posts...but it is everyones enthusiasm and passion that make this such a great resource. Thanks Pelican.
Here is one that I cannot find ......
This is the header/exhaust system that I purchased the car with. I can find no other markings on it except for the name on the muffler (assume that it is the muffler manufacturer only). All the headers are pretty much equal length (32").
1. Does anyone know the manufacturer? I would like to inquire about making it a dual exhaust.
2. How do you think this system compares performance wise to what others?
I do remember the PO telling me to not get rid of the exhaust system and that it was pretty expensive- but who knows...
-g
http://forums.pelicanparts.com/uploa...1062171241.jpg
another pic
here is another shot-
http://forums.pelicanparts.com/uploa...1062171344.jpg
sean_V8_914 08-29-2003 08:11 AM
the flanges do not look like they will fit a T-IV. Do they?
John Rogers 08-29-2003 08:21 AM
They look like a set of European headers, made in the LA area such as I had on my race car. They worked great and the muffler was quiet enough to meet the noise restrictions at the SD stadium. They should also have a "stinger" you can use after you remove the muffler when noise is not an issue.
DuckRyder 08-29-2003 08:35 AM
Pretty strange.
The header looks much better quality than most "PaceSetter" stuff. (Nopi does or did sell PaceSetter Monza stuff. The 240Z header is utter crap, and the 510 header isn't much better.)
That cylinder closest to the muffler has issues.
Dave at Pelican Parts 08-29-2003 09:09 AM
It does look similar to the "European Racing" headers that John mentioned. Not sure if it's the same or not. It's a good-performing system, though the CFR (or Tangerine Racing) one is supposed to be better. If it's a European Racing one, it is reputed to be midway between Kerry Hunter and Tangerine Racing both in price and performance.
--DD
John Rogers 08-29-2003 10:12 AM
I looked at the picture again and it seems like you are missing the 4 stub pipes that bolt to the header and the head??? You should make sure you have them as they are made for each set of headers!! The cost of a European system is about $400 or so if I remember correctly
BGman 08-29-2003 10:53 AM
Sean and JR-
You guys are sharp. The 4 stub pipes I did leave bolted to the engine (which is off at Raby's turning into a 2270).
So this is a "pace setter" system?
I searched the net...maybe I will look again.
DuckRyder 08-29-2003 11:21 AM
Actually, I wasn't clear earlier, But I don't think it is a pacesetter, it looks too nice. Probably just the muffler came from them.
Is it stainless?
Fly Mach .86 08-29-2003 11:43 AM
Hi,
I had my engine built by the folks at Fat Performance and the header they supplied is exactly the same as the picture. (Except mine looks nicer.) I don't know who made the header but will find out if you want.
Cheers, Elliot
BGman 08-29-2003 11:55 AM
Fly- would appreciate it. I have looked all over and cannot find any markings- not a number or even a stamp.
DR- I am assuming it is stainless. There is not a coating to chip or crack off. Actually you have got me thinking... what is the best method of cleaning this thing up for the new engine if it is stainless?
Fly Mach .86 08-29-2003 01:02 PM
Hi,
I just spoke to Greg at Fat Performance and he said they are European Racing Headers and they are in Nevada. Fat Performance is a distributor and can get them for you if you want. You can reach them at 714 637 2889.
Cheers, Elliot
chrisreale 08-29-2003 01:14 PM
Paragon Products also has them. www.*****************.com
