stripped head bolt
I took my carbs off when I put the engine in the car. As I was putting the carbs back on and tightening the bolts down one of them pulled straight out of the head with aluminum in the threads. What is the suggest procedure for fixing this?
CoryB
brownc@rohan.sdsu.edu
Old 08-27-2003, 07:41 PM
canna change law physics
red-beard's Avatar
2 choice, both require drilling.
drill and tap for 10mm, use a 10mm/8mm stud
drill and insert an 8mm thread insert
There are advantages to both.
James
James
Red-beard for President, 2020
Old 08-28-2003, 03:59 AM
Thank you for the reply red-beard. I don't know if I want to attempt to redrill the head myself. The middle bolt is the one that is stripped...do you think that once I get it running I could drive it to a shop so they could fix it...or would it leak gas? Does redrilling require the engine to be dropped?
CoryB
Old 08-29-2003, 11:46 AM
red-beard's Avatar
It will not leak gas. The manifold is running less than atmospheric pressure. It will leak ait into the manifold making the car run lean.
You might use to silcone RTV around the manifold as a temp fix to help get you to the dealer. RTV comes off pretty easily.
James
James
Old 08-29-2003, 12:26 PM
mike95125's Avatar
I just did this this morning (about 3am). I used a timesert kit to reinstall a threaded sleeve. I used the provided drill bit and a T handle and drilled it by hand. You need to take your time or you will end up crooked (ask me how I know). The time sert kit is pricy, though. I was lucky that Sean_v8_914 had a kit to loan. It may be just as easy to put a larger stud in there.
HTH
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 08-29-2003, 02:03 PM
