removing axels
I was able to remove the axel side that connects to the transmission, but when removed the bolts from the other side connected to the hub it won't come off. All four bolts are off and I pull on it with some force but it wont budge. I tried taking off the 32mm bolt connected to the hub but it was rusted on. Will the axel not come off if the 32mm hub bolt is still on, or am I just not pulling hard enough on the axel? Thanks in advance.
CoryB |
This http://forums.pelicanparts.com/showthread.php?threadid=117069&highlight=Removing+ the+driveshaft thread should answer your question.
i was able to separate the inner CV from the stub axle with little problem. maybe just need more persuasion:D
There are 2 spiral pins that help to secure the CV from the stub axle. Subsequently, it may not be possible to separate the 2.
You just have to keep tugging on them. They'll come. There siezed around those guide pins. Good Luck |
| All times are GMT -8. The time now is 09:31 PM. |
