removing axels
I was able to remove the axel side that connects to the transmission, but when removed the bolts from the other side connected to the hub it won't come off. All four bolts are off and I pull on it with some force but it wont budge. I tried taking off the 32mm bolt connected to the hub but it was rusted on. Will the axel not come off if the 32mm hub bolt is still on, or am I just not pulling hard enough on the axel? Thanks in advance.
CoryB
brownc@rohan.sdsu.edu
Old 08-29-2003, 12:42 PM
Banned
Alfred1's Avatar
This Removing the driveshaft from the stub axle. thread should answer your question.
Old 08-29-2003, 12:53 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
i was able to separate the inner CV from the stub axle with little problem. maybe just need more persuasion
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 08-29-2003, 01:01 PM
cary's Avatar
There are 2 spiral pins that help to secure the CV from the stub axle. Subsequently, it may not be possible to separate the 2.
You just have to keep tugging on them. They'll come. There siezed around those guide pins.
Good Luck
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 08-29-2003, 08:45 PM
