914 V-8 conversion engine question
Well, i went over to Scott's house and picked up all the empty propel bottles.
![]() What's the best cam / carb combo? i've got a SBC 302 ?
71 914 2.6L Big 4 Midnight Blue Pearl 72 914 V-8 32' Uniflite Sports Sedan "Island Chaser" |
I wish I had a dime for every penny I ever had. http://www.914club.com/bbs2/uploads/blog-1136350347.jpg |
Hey Joe, you should be bold and go with about a 292 duration and a 488 lift. That should give you a nice lopey idle and plenty of power to scoot right along. Be sure to get the billet intermediate plate and do not use first gear. As for the carb, you should just pick up the Edelbrock 650 spreadbore. I think it will work best for you.
http://www.pelicanparts.com/gallery/skline It's easier to get forgiveness than it is to get permission. 75 Slantnose V8 03 S-10 Extended cab stepside in Yellow 72 914 Parts car |
Hey Miles, did you spell Camaro wrong? I tried the link and it fails. Lets try this one. www.camaro.com
grind weld build
call the edelbrock tech line. they are very helpful. Vic edel brock raced oen ofthe original Camaro 302s and tehy have developed several cams for that mojo combo
http://www.edelbrock.com/automotive/index.html
flesh heals, memories last forever! 73 Orange, CS #601 73 Rayco V8 glug, glug 69 911 w/82 turbo look on 275 35 18s (for sale) Trek 6500+ Sean M! |
Unregistered
I made the mistake of having an RV cam in my 350 chebby powered 914, I always wanted to change to a cam that would give me more top end but never got around to it. The RV cam doesn't work well with a 901. It pulls real hard from the bottom but falls on it's face at 5200 rpm.
Talk to the cam manufacturer and tell them you want the powerband to go from 3800 to 6500 (flat tappet) or 3400 to 6800 rpm for a roller lifter set up. They will be able to match the other compnents and your heads and give you the cam you want. BTW, you probably don't want to spin it that fast but you will want to have the ability to properly match the gear ratios. Hope you have a friend with a gas station ![]() |
Unregistered
I just remebered something:
Rod Simpson advertises a special 914 V8 cam he came up with that supposedly revvs forever and still gets 30 mpg. I don't know how but that's what he says. Check his website or give him a call, he's real friendly to talk to. |
I'd love to have a 302 for my conversion but they don't seem readily available or inexpensive. I thought I'd start with a 327 or 2-bolt 350, then later put in a 283 rotating assy, appropriate heads/ cam/ manifold/ carbs for a pseudo-302. Keep us posted as to what combo you use!
Ed
'74 914 V8 '70 914 |
=oP You know, do live in GA. M
Hey Hendrix that was a good one - The guy I work with kept telling me to "open it in a different window, I wanna see it too........oh"
-"Let's git us some pork rinds, an' head on downta the crick"
- "NOW" Magically Delicious - |
cant go wrong with the "151" camshaft from Chevrolet. It is the original 350hp, 327 cam. This would work well in a 302. If you could find a factory aluminum Z-28 manifold, you'd be in hog heaven.
grind weld build
edelbrock suposedly copied and improved upon teh Z 28 to come up with the Performer intake
My father's last words were: "Hay! Lookat thius!"...as were his father's, and his father's before him... You just wait til I get underway tomorrow... I'll show ya something! M
