auh auh is offline
auh's Avatar
Send a message via AIM to auh
No Brights
I don't have brights on my car.
I have the indicator light for them and the switch moves, but when I pull back the turn signal lever, nothing happens.
What could be wrong and what would it take to fix?
Adam
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 09-07-2003, 02:31 PM
mikester's Avatar
Send a message via AIM to mikester
Check the fuses first. I on occasion hit them with my foot on the way out of or into the car. Knocked the fuse for one side of the headlights off once, bought a new headlight. Installed it - still didn't work. Checked the fuses - fixed it.
-The Mikester
I heart Boobies
Old 09-07-2003, 03:18 PM
auh auh is offline
auh's Avatar
already changed the fuses, didnt do a thing
Old 09-07-2003, 08:05 PM
Drop the fuse panel and check the wires on the corresponding terminals. These are high current lines and the crimp terminals can get loose and oxidized, even come off. Seems your relay is OK since the indicator lamp is working.
Old 09-07-2003, 09:40 PM
Send a message via Yahoo to dharder
Can you hear the relay clicking as you actuate the lever? If you have the blue high-beam indicator light come on in your dash, you probably can (hear it, that is). The high beams are actuated by a small set of points in the turn signal switch that get closed when you pull the turn signal lever back. You can see them if you look in from the left side of the steering wheel in front (towards you) of the lever. Make sure these points are making contact. Sometimes they just wear out and don't make contact.
Old 09-08-2003, 04:43 AM
auh auh is offline
auh's Avatar
I don't hear a click of any kind when I pull back the lever. I'll check on those points and get back to you.
Adam
Old 09-08-2003, 05:20 AM
grind weld build
sean_V8_914's Avatar
have you ever had them working since you own this car?
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 09-08-2003, 09:38 AM
auh auh is offline
auh's Avatar
ive only owned for 2 weeks
Old 09-08-2003, 12:58 PM
I would replace the relay. I had a similar problem & this fixed it. Also, check to make sure the relay is grounded. My relay had a little metal clip that grounded to the fuse panel (just by snapping in place). As soon as it was grounded, it started working again.
Old 09-08-2003, 01:24 PM
grind weld build
old style relay was self powered. new style relay requires a jumper to power the relay. I'll look up the contact numbers tonight in the manual.
73 Orange, CS #601
Trek 6500+
Sean M!
Old 09-08-2003, 02:31 PM
Here's part of the wiring diagram for a '74.
It's not yet clear to me if the high beam indicator is working or not ("I have the indicator light for them"). If not then chase after the relay. If the indicator (K) is working then from the diagram there should be 12 v on the fuses S1,2 which feed the hi-beam filiaments. Then you've got something else wrong. Maybe the filaments are burned out or wires are off.
Old 09-08-2003, 04:00 PM
