D7N7MASTER's Avatar
Unhappy Rear Trunk Unlatches
Hi All,
My rear trunk unlatches while I'm driving. But when I close it, it locks & won't open even if I tug on it. When I activate the solenoid it opens fine. What's Up???
Thanks,
Gary
If it was easy - anybody could do it...
www.pelicanparts.com/gallery/d7n7master
Old 09-19-2003, 08:59 AM
ruddyboys's Avatar
Did you forget to take the exwife out of the trunk?
74 LE "Bumblebee"
03 Jetta Wagon
Old 09-19-2003, 09:28 AM
D7N7MASTER's Avatar
...My exwife wouldn't fit in the trunk.
Old 09-19-2003, 09:43 AM
John Rogers's Avatar
We had this happen on our 1974 and the latch parts were worn just a tad too much. When driving the body would flex or twist some and be just enough to get th elatch to pop loose. You could try adjusting it a little tighter but replacement is usually the cure. I think replacement parts are still available too?
Old 09-19-2003, 09:58 AM
slowlane
Guest
Posts: n/a
especially if the trunk is jostling around sideways so that the actuator (plunger) is pulled out of position by inertia. maybe also an intermitant short?
Old 09-19-2003, 10:34 AM
D7N7MASTER's Avatar
I installed a new upper latch - but no help.
Old 09-19-2003, 11:24 AM
kellzey's Avatar
It's the lower part. Maybe the little cam thingy. It's easy to remove, insepct, and replace.
Qarl
Old 09-19-2003, 11:44 AM
Banned
Alfred1's Avatar
ROFLMAO! I found that answer hilarious. Ok, not many people would fit in a 914's trunk but if he owned a big ol' Cadillac or something that would be a great insult directed at the ex-wife!
Old 09-19-2003, 11:55 AM
slowlane
Guest
Posts: n/a
you gotta cut them up a bit to fit...
Old 09-19-2003, 12:27 PM
kellzey's Avatar
If she is too big... remember... you have TWO trunks! Ha ha!
Plus it will help with the weight distribution for better handling!
Qarl
Old 09-19-2003, 12:41 PM
Kenny Powell's Avatar
You just have to play around with the adjustment on the top piston............I had to do that until I found the sweet spot!
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 09-19-2003, 01:15 PM
D7N7MASTER's Avatar
Talking
Thanks for the input. I've adjusted the upper latch to the point where the solenoid won't open the trunk. Had to pull the release wire from under the trunk to open (so THAT's what that's for...)
Re-adjusted...just a little. Drove around the block & it stayed closed. Real test tomorrow - after I drive it to work.
Old 09-21-2003, 06:25 AM
skline's Avatar
I had to replace the lower part. I tried everything. Got a new one and it works fine now.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 09-21-2003, 08:10 AM
D7N7MASTER's Avatar
(skline) I'm in Buena Park, Ca. I see your in Costa Mesa... where did you buy the lower part??? Thanks,
Gary
Old 09-21-2003, 07:03 PM
skline's Avatar
I got it from Ron Meier awhile back. I actually have a few of them here but we were out on the Temecula Run and I needed it.
75 Slantnose V8
72 914 Parts car
Old 09-21-2003, 07:13 PM
