Spark Plugs for a stock 2.0 FI
What plugs should I run and what gaps on a stock 2.0 FI.
Thanks, Tod |
I use the factory-specified Bosch W7CC, the spec gap is 0.7 mm. I've used Bosch W7DTC's before, I thought they worked quite well - copper core with triple-electrode.
This page has all of the plug specs (as well as many other specs) for the 914. Note that most/all of the plug numbers are probably superceeded and will need to be checked against current reference guides. http://www.porschedecals.com/history914wcodes.htm |
Banned
When you need Wires we have the set that fit the 2.0. These are extra long with 4 98mm Connecters, they are $30.00 Steve
